Looking into a new Receiver Best for aroudn $1000?
Discussion in 'Archived Threads 2001-2004' started by Christopher M, Feb 10, 2003.
  1. Christopher M
    Christopher M Stunt Coordinator
    Feb 24, 1999
    88
    I'm looking at new receivers, just to see what I can get.
    I'd like to stay around $1000.
    I want:
    DTS
    DTS-ES
    Component input (at least 2) (for my DVD, possibly HDTV Later)
    I'd like to get 7.1 if possible, if not, then 6.1
    Right now, I'm looking at the
    Denon AVR-3803
    Any others you recommend?
    Thanks.
  2. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    Sony 4ES. Spend the cash you save on DVDs.
  3. jeff_coil
    jeff_coil Stunt Coordinator
    Dec 3, 2002
    157
    You can't go wrong with the Denon. The upconversion is nice and it works well in my system. I was torn between the rotel 1055 and the Denon when I went through it and ended up with the Denon with no remorse
    cheers
  4. Pablo Abularach
    Pablo Abularach Supporting Actor
    May 27, 2002
    526
    Cristopher,
    Here are some suggestions,
    Harman Kardon AVR525
    Marantz SR7300
    Onkyo SR800
    Pionner Elite 45TX
    Yamaha RX 3300
    Every people have different preferences, try to audition as much as possible, and if you can with the speakers you have or will buy.
    Hope this helps,
    Pablo
