NeelMehta
- Sep 22, 2000
Hi,
I currently have a budget HT setup and am looking to upgrade:
Current setup
Yamaha RX-V592 receiver with Yamaha DVD-s700 dolby digital decoder
Klipsch KG 3.5 fronts
Klipsch KV3 center
Klipsch KG 1.5 rears
Sony SA-WM40 (modified)
My feeling is that the receiver is the weak point, mainly the internal amp being only 75watts. My guess or plan was to make use of the external amp inputs and connect it to an outboard 5 channel amp.
Would this make sense or would it be more advisable to purchase an upgraded receiver. I am not too interested in some of the newer formats, i am happy with Dolby Digital and just want to see if a new amp can upgrade the sound.
If it is the correct move, any budget amps to consider? I wanted to spend
Current setup
Klipsch KV3 center
