Looking for thin center channel - 4" or less deep!
Discussion in 'Archived Threads 2001-2004' started by RandyL, Nov 16, 2001.
  1. RandyL
    RandyL Agent
    Mar 7, 2001
    46
    What's out there? I've found the Acoustic Research "phantom" line, wondering if there's anything else?
  2. Jeffrey_Jones
    Jeffrey_Jones Second Unit
    Nov 6, 2001
    283
    Hi,
    Out of curiousity, what is the application? Why the depth requirement? Maybe the "think tank" that is this site could help you find an alternative that doesn't limit the size of the center channel.
    - Jeff
    My Homepage
  3. MatthewJ S
    MatthewJ S Supporting Actor
    Feb 27, 2001
    584
    Vienna Acoustics Waltz
  4. RandyL
    RandyL Agent
    Mar 7, 2001
    46
    Hmmm.. $650 is more than I want to spend.
    [Edited last by RandyL on November 16, 2001 at 11:09 AM]
  5. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    The base of Infinity's Entra Center is 4.5" (before the bezel which tapers up). The full depth without grill is about 5.5" and 6" with the grill.
    John Golitsis
    Next Big Thing Electronics
  6. Thomas_Berg
    Thomas_Berg Screenwriter
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    Bose [​IMG]
    -Thomas
    My HT
  7. Bob_A
    Bob_A Supporting Actor
    Jul 30, 2000
    876
    I'll second the BOSE recommendation [​IMG]
  8. RandyL
    RandyL Agent
    Mar 7, 2001
    46
    As this is for a simple living room HT and not our future basement all-out-awesome HT, I actually looked into the Bose VCS-10 but couldn't bring myself to even consider it after reading 20 negative and 0 positive reviews. [​IMG]
  9. Larry Hoffman
    Larry Hoffman Stunt Coordinator
    Jul 2, 2001
    102
    It's not as small as 4" in depth, but the Mission M7C1 is a rather good looking slender center, compared to most others in its price range. It also isn't plagued with the thin sound you get from most of the tiny centers on the market and is therefore suitable for a larger room than those small systems are. The matching bookshelves are also reasonably priced and good sounding.
    You can probably buy it for less than $250.00 (Canadian). It's 5.25"h X 5"d X 20"w.
    Below is the URL to Mission's site. Go to the M70 series.
    http://www.mission.co.uk/main.htm
    Larry.
  10. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    Brett Andrew DiMichele
    Randy,
    I think you should strongly consider your first choice.
    The AR Phantom Series is a VERY high quality component
    speaker set. The drivers are Carbon Fiber cone's MFD'd
    by DynAudio and the enclosures are aluminum (the insides
    are sprayed with neoprene so they are anti-resonant)
    Also check out the AR4C.. I have one and love it.. I
    will measure the depth if you want me to.. But it's
    not silver so it's not going to match your Scentium
    if that is a major concern.. The AR4C is part of the
    Hi-Res line which is a lateral move to the Phantom
    Series, they are both equaly Hi End.. (IMHO)
    [​IMG]
    Brett DiMichele
    My Home Theater Site!
    [email protected]
  11. RandyL
    RandyL Agent
    Mar 7, 2001
    46
    The Infinity Entra Center is out - I went to look at it and the cloth grill isn't black, it's PURPLE... kind of clashes with my room [​IMG]
    I actually owned the Acoustic Research Phantom setup about a year ago and liked it a lot. The 252C is high on my list right now.
    Other choices I've seen are the centers from the Polk RM series. They're all compact and thin, and seem to garner excellent reviews as well. But the woofers aren't nearly as big as a 'real' center channel.
    Ideally I'd like to find a set of in-wall speakers to match this center channel. Acoustic Research doesn't make in-walls, and Polk's don't seem to match the same tweeter as in the RM series to anything else. So I'll keep looking [​IMG]
  12. JohnnyG
    Dec 18, 2000
    1,522
    The grill of the Entra Center is definitely supposed to be black! The Interlude series has different grill colors available and maybe a blue grill from an IL25c was on the Entra speaker by mistake.
    Besides, the speaker is just gorgeous without the grill!
    John Golitsis
    [Edited last by JohnnyG on November 17, 2001 at 01:23 PM]
