looking for speakers to match receiver
Discussion in 'Speakers & Subwoofers' started by emile engel, Jun 24, 2003.
  1. emile engel
    emile engel Auditioning
    Jun 19, 2003
    8
    hi there folks,
    looking for speakers to match a Yamaha RX430 receiver 65x5 rms per channel.
    Have read that the receiver sound is bright, what speakers should i look for, brand names that match this particular receiver.
    Considering B&W, Missions, or Wharfedale. This is from responses i've had, but open to any suggestions.
    Thanx in advance
  2. Chu Gai
    Chu Gai Lead Actor
    Jun 29, 2001
    7,270
    Well I don't put much stock into this thing of receivers being bright or forward or warm or having some sort of attitude. Your perception of the 'quality' is a function of your speakers and room interactions. That said, and not knowing what's available where you live, and keeping in mind that this is an entry level receiver, I think you should focus your attention on speakers with good sensitivity that are 8 ohm nominal impedance. What's available in your price range where you are only you can answer.
  3. Ernest Yee
    Ernest Yee Supporting Actor
    Jun 6, 2003
    539
    Yeah- w/ an entry level receiver, you should get the best bargain in terms of high quality speaker that you can get and worry about matching it w/ the receiver later.
