Looking for something like Paradigm Seismic 12 but under 1k?
Discussion in 'Speakers' started by michael_tran, Jan 19, 2006.
  1. michael_tran
    michael_tran Agent
    May 28, 2002
    34
    I dont have a lot of room, and really like the performance of Seismic 12, small, powerful, earth shaking performance, but one thing that I dont like, price, is there anything out there will match the performance with small profile like that under 1K? I listen mostly 70% movie, 30% music, thanks.
  2. DarrenAlan
    DarrenAlan Stunt Coordinator
    Jul 23, 2002
    172
    If your room is pretty small, the Seismic 12 strikes me as overkill. For smaller subs in your price range, I'd look into Sunfire, the Velodyne SPL-R series, and the Pinnacle Baby Boomer, in that order.
    I have a Pinnacle SubSonic, the Baby Boomer's little brother, in a room 17' x 20' x 20' and it certainly fills the area with loud, tight bass. That's mostly for music, though; YMMV.
    Good luck and happy hunting!
  3. Jacob C
    Jacob C Second Unit
    Mar 19, 2005
    257
    Check out HSU and SVS but the cabinet are probably bigger than what you are looking for. Check out Onix Rocket Subs You can get a pair of the 10" for $1000 or single 12" for $1100. The single 10" goes for about $600. I've heard nothing but good reports about these units. I think it would be worth your time to listen to one.
  4. michael_tran
    michael_tran Agent
    May 28, 2002
    34
    thanks guy, I also found Paradigm pw-2100 and/or pw-2200, are they as good compares to svs and the like? I believe those running under 1K? specially if we can do a little driving to can.
  5. Jacob C
    Jacob C Second Unit
    Mar 19, 2005
    257
    Many think, myself included, that you just dont get much bang for the buck with paradigm subs. Their fullrange speakers are great I think HSU, SVS, or Onix Rocket are going to give you the most for the money. Right now I am eyeing up the new HSU VTF3-HO its sounds like it will be an absolute monster. Right now you can get it under $1000 with the turbo. The turbo basically extends the length of the port for a lower tuning.
