Looking for some advice...
Discussion in 'AV Receivers' started by Parker Parrish, Dec 1, 2003.
  1. Parker Parrish
    Parker Parrish Auditioning
    Nov 30, 2003
    Hello,
    My name is Parker Parrish and I am trying to set up a reasonably priced (cheep) home theater system. I have a DVD player with a digital coax out and an old CD changer with an RCA out. They (along with the TV and tape deck) run into an Onkyo Tx-8511 stereo receiver that powers two Tannoy 609s. The speakers were given to us and I came across this info on the web:
    8" Dual Concentric with tulip wave guide
    8 Ohm
    Sensitivity ([email protected]): 89dB
    Freq. Res. +/- 3dB: 46Hz - 30kHz
    X-over: 2.5kHz
    I have been looking at the Pioneer VSX-D912 and was wondering what the current opinion of it is. Is there anything else similarly priced that you would recommend?
    The way my room is set up is a little odd. The main seating is forced up against a glass door so if I wanted 6.1 sound, the rear center channel would have to be mounted about 3.5feet above and a mere 5 inches behind me. Would I still get the same effect or should I not even bother and stick to 5.1? Also, any recommendations on speakers? I would like to keep the receiver and speakers under $700 so I know my choices are limited. I can’t afford “perfect” so I’m looking for the closest my budget will allow. I’d love to be able to use the Tannoys but I am afraid I won’t be able to match the sound to anything else. Thanks for reading this and I’m sure you can tell I need all the help I can get!
    Parker Parrish
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Welcome to HTF, Parker.
    Since you're asking about a specific receiver here, this is the section where you should post. The Basics area is a place where newcomers can ask the very basics, as in "What is a receiver?"
    Good luck.
  3. John S
    John S Producer
    Nov 4, 2003
    5,460
    Are your other surrounds mounted 3.5' above ear level as well? I think you would still get the advantage of 6.1 from it, not optimal, but HT in a living room is always full of some compromises.
