adamSL
- Mar 2, 2006
I currently have a homemade PJ screen that has a 113" 1.3 gain Ultra white screen from Carl's Place. I love it, but I have a problem. I have a homemade screen in which I stapled the screen to a frame. Over the course of time the screen starts to wrinkle - I suspect that part of the reason is the change in temperature in my basement theater room (the wrinkling seems to happen in the winter when I use the heater. Anyway, I am not sure that I would be able to staple it again and it is a bit of a pain to do so as I have to take off the wooden frame.
Anyway, I am thinking about buying a screen so that I can be done with this nonsense. If I buy a thin border I can upgrade to 120" screen. I currently have a mid-level 4k benq with about 2000 lumens. The room is in the basement and thus ambient light is not a problem. The viewing position is straight on. There is an elite screen for about $400 that is 1.1 gain. At $600 there is another model with 1.2 gain. Should I be concerned about the difference in gain? I've read a bunch on the topic and there seems to be a lot of "it depends" opinions on the matter. The vast majority of my viewing is movies at 1080p or 4k quality.
