Looking for CRAZY ROOM SHAKING bass...
Discussion in 'Speakers & Subwoofers' started by AndrewGA, Feb 8, 2006.
  1. AndrewGA
    AndrewGA Auditioning
    Feb 2, 2006
    8
    Looking for bass that will provide pressure in a fairly 600sq. foot room. It will be used with JBL e90s and a HK-3480 receiver. I want it loud and I want it to hurt. SPL is more important over SQ, but nobody likes muddy sounding bass.
    Considerations:
    1) 2 Dayton 12" = Around $300 shipped
    2) 2 JBL E250s = Around $500 shipped
    3) Dayton 15" Titanic kit = Around $700 shipped
    Any other considerations would be great...
  2. BenLev
    BenLev Agent
    Feb 7, 2006
    37
    I used to own a dayton 12. I now have a SI mag 15 and it is 10 times better than the dayton. I have my sub hooked up to a plate amp putting out around 1000rms and I am sure it would be good enough for a 600 sq ft room. Mine is in a 400 and I can't even turn it up all the way without thinking the walls are going to fall down. If you are going to spend around $400-500 I would consider it. If you are looking for a decent sub for 120 just go with a dayton though. Personally I just was never happy with it.
  3. AndrewGA
    Feb 2, 2006
    8
    I'm mostly leaning towards the Dayton Titanic MIII... does anyone have any experience with this subwoofer?
  4. BenLev
    BenLev Agent
    Feb 7, 2006
    37
    For the money they aren't worth it. But if money isn't a big deal and you want something that comes in an enclosure already and easy to use, then go for it.
  5. AndrewGA
    Feb 2, 2006
    8
    Also considering SVS upper end subwoofers... SVS PB12 ect
  6. BenLev
    BenLev Agent
    Feb 7, 2006
    37
    I am going to have to buy one of these svs subs. I can't imagine it would be any better than what I have now and the prices are incredibly high. I doubt it will even be better than an Adire Tumult.
  7. Reginald Trent
    Reginald Trent Screenwriter
    Feb 18, 2000
    1,313
    So which sub do you have already BenLev? BTW I vote for the 16-46 PCI for CRAZY ROOM SHAKING BASS.
  8. SethH
    SethH Cinematographer
    Dec 17, 2003
    2,867
    Incredibly high prices?!?!
    Compared to DIY, sure. Because you don't consider your labor as part of the cost. Point me to the pre-made subs that will outperform SVS in the same price range. Hsu and a few others will meet or maybe slightly pass SVS in some of the various price ranges offered, but I don't think there's much of anything that will provide significantly better performance for a lower price.
  9. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,303
    59
    9,110
    Mississippi
    You can't compare a raw driver to a completed sub. The enclosure will make a huge difference in whether or not it will be "better".
    -Robert
  10. BenLev
    BenLev Agent
    Feb 7, 2006
    37
    Ok I get it now. I have been building enclosures for a few years now so it isn't a big deal to me. I do understand that there is extra labor involved when buying a raw driver. I guess if you don't know anything about box building then it is better to just pay more and go with one that comes already made for you.
    And I have a SI mag 15.
  11. SteveCallas
    SteveCallas Second Unit
    Dec 23, 2003
    475
    I highly doubt 2 Dayton 12" will give you crazy room shaking bass. If DIY is not an option, and you really do prefer spl over sound quality, and you want crazy spl, it sounds like you want a pro subwoofer, something like this:
    http://www.topdjgear.com/cv-lr-36.html
  12. Tom Vodhanel
    Tom Vodhanel Cinematographer
    Sep 4, 1998
    2,215
    8
    That CV unit won't need much amp either...106dB/1w. Pick up a cheap 100w amp and you could expect 120dB or so. Extension might not be that great...but it will hit pretty hard from about 40hz and up..[​IMG]
    Tom V.
    SVS
  13. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    Buy the Titanic kit and have someone drop it on you. That should cover both requirements.
    [​IMG]
  14. Kenneth Harden
    Kenneth Harden Screenwriter
    May 13, 2002
    1,365
    If you want maximum bass - I would personally rule out a sealed sub.
  15. JediFonger
    JediFonger Producer
    Feb 2, 2006
    3,968
    26
    1,610
    YiFeng You
