Looking for Component to VGA cable
Discussion in 'Archived Threads 2001-2004' started by Robin Chen, Dec 17, 2001.
  1. Robin Chen
    Robin Chen Auditioning
    Dec 7, 2001
    6
    Can anyone direct me where I can find this kind of cable? I need to connect the component out from a progressive DVD player to a computer monitor that only has a VGA input. I think there must exist this type of cable because I see that a lot of older plasma TV only has this type of connectors, other than the S-Video and composite video input. If there isn't such a cable already for sale, what does it take to build one?
  2. Ron Boster
    Ron Boster Screenwriter
    Jan 10, 1999
    1,145
    Robin:
    I know it can be made, whether it functions correctly(?). Contact Brad Marcus at www.bettercables.com He can make this cable for a reasonable price.
    Another question might be could one use an RGBHV to vga cable....using only the RGB plugs and leave the H and V unused and dangling? Something tells me that is possible.
  3. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
    Hi Robin,
    You didn't say what brand/model display it is.
    Try keydigital.com and copperbox.com. They have such a device.
    Errol
  4. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    You also need a box in between with circuitry (a transcoder) to convert the component video to RGB, which VGA is, unless the monitor or DVD player has a selection (always manual) to do that transcoding. I do not know where to obtain the transcoder or how much you would have to spend.
    Other video hints:
  5. Ka Yuen
    Ka Yuen Agent
    Mar 14, 1999
    35
  6. Robin Chen
    Dec 7, 2001
    6
    Thanks for all your help. It looks like I would need to get the Componenet to VGA transcoder in order for this to work. Copperbox.com has the cheaper transcoder for sale. Would there be any quality differences between the one offered by copperbox and the one from keydigital?
    Robin Chen
  7. errol
    Dec 29, 1999
    150
    Hi Robin,
    Key Digital is the transcoder manufacturer. Copperbox is one of its distributors/reseller.
    Errol
  8. Ka Yuen
    Ka Yuen Agent
    Mar 14, 1999
    35
    audioauthority.com sells a VGA to Component Video coverter for $129.
  9. Michael D. Bunting
    Michael D. Bunting Screenwriter
    Jun 9, 1999
    1,828
    Michael
    I have the Audio Authority VGA -> Component Converter for sale here on the HTF:
    http://www.hometheaterforum.com/htfo...threadid=38377
    Let me know if you are interested or have any questions.....
    [email protected]
