Looking for case feet
Discussion in 'Archived Threads 2001-2004' started by Bill Catherall, Jun 21, 2002.
  1. Bill Catherall
    Bill Catherall Screenwriter
    Aug 1, 1997
    1,560
    You know those feet that are found on most home audio equipment with the band of aluminum around them to look cool. Like the feet found on this receiver, for example.
    Is there anywhere those are sold for adding to a desktop computer case? I think they'd look good on an HTPC sitting in an AV rack.
  2. Bill Catherall
    Aug 1, 1997
    1,560
    So I take it the lack of responses means "there ain't none?" [​IMG]
  3. Jay H
    Jay H Producer
    Mar 22, 1999
    5,654
    33
    Pittsfield, MA
    Jay
    Hi Bill, have you thought of contacting Yamaha or Denon or any of them???? I'm sure you could buy parts from them and mod it to fit you're case. I think most of them are simply threaded screws you screw into the bottom of the receiver. My old Denon CD player had something like that...
    You might also try to ask a local service center if you can buy parts from them and see if they have what you're looking for. might be cheaper, easier, and faster than dealing with a manufacturer directly...
    Jay
  4. JasenP
    JasenP Screenwriter
    Dec 21, 1999
    1,280
    110
    Kalamazoo, MI
    Jasen
    I would check and see if the local dealer has a dead unit that you might scavenge your parts from.
  5. Bill Catherall
    Aug 1, 1997
    1,560
    Thanks for the advice. I'll look into those options.
