Trenton McNeil
- Apr 30, 1998
I would like to set my subwoofer to the appropriate crossover level in balance with my other speakers, as well as graph the response curve of my entire system in my front room, from various listening positions, to help determine how much eq would be needed to correct tones, as well as experimentation with sound damping on walls, etc.
What I do NOT want to do is go out and buy huge passive xover systems for each output....I do not run separates currently, so if I must go with eq, it will be an expensive proposition...
That said...what would be best is a good full range mic combined with software with which I can use a laptop to graph response curves, as well as the best test tone software or cd/dvd's for these tests.
This seems best suited to the expertise of the DIY group, forgive me if I have posted in the wrong forum.
Thanks in advance!
-tm
Thanks in advance!
-tm
