Paul Spencer
- Sep 15, 2003
- Paul Spencer
I'm looking for a HT receiver which has preouts and main in for all channels. I've found some only have direct inputs, what is this exactly? Is it a digital input that will then go to a DAC then preamp and power amps?
This gives me the flexibility to insert EQ into all channels as well as use active crossovers without having to come up with so many extra power amps.
Also looking for:
*4 ohm stable
*reasonable budget
The only amp I have found so far is the NAD T743 and T753, the former having main in only for the front 3 channels.
Denon seem to have no preouts and only handle 6 ohms.
Marantz have pre outs but don't seem to have any with main in (that I have seen).
Harmon Kardon only have this feature with their very expensive models.
Yamaha only seem to have preouts, and that is on their more expensive models. I downloaded some manuals in PDF format, but they won't open :frowning:
Also looking for:
*4 ohm stable
*reasonable budget
