Darren Gross
- May 16, 2001
I recently purchased a Denon AVR-X1600H. I previously had a 1906 which had no HDMI inputs, etc. so I thought it was time for an upgrade. The problem is nothing looks in sync to me. I'm using high-speed HDMI cables and eventually gave up and have nearly all my devices plugged into the TV and am using the TV HDMI out to the receiver as the problem seems less bad that way. I've tried auto mode, direct, pure direct, with lip sync correction and without, and adjusting the milliseconds as well, and the more I mess around the more things look off. It's gotten to the point, that I'm so far down the rabbit hole, that nothing looks in sync, not youtube videos on my computer or anything else.
Does anyone have any recommendations for discs, DVD and/or blu ray or even streaming versions, as I need to fix all inputs for scenes/ sequences which are ideal to use to adjust sync?
I'm this close to just saying screw it, and re-installing my previous received and returning the new model, as what was supposed to be a fun upgrade has turned into a complete headache.
Thanks!
Thanks!
