Looking for an HDTV receiver...completely lost!
Discussion in 'Archived Threads 2001-2004' started by Joe Ferreira, Feb 1, 2003.
  1. Joe Ferreira
    Joe Ferreira Stunt Coordinator
    Jan 17, 2003
    68
    I just got my first HDTV today. It's a Samsung 32" (not much, but I love it). So I was hooking up my RP-82 DVD player using the component inputs and got to thinking: isn't this the way that you hook up an HDTV receiver? Problem is this TV only has one set of component inputs. So anyways, I have cable TV but would like to pick up some of the HD signals coming through the area here in Oklahoma City. What exactly do I need? How do I go about hooking everything up? I still want squeeze on my progressive scan player. What kind of prices am I looking at? Thanks in advance!
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    What kind of receiver or pre/pro do you have? Most of the fairly new ones above a certain price point will have component switching capability. Or if that's not an option, there are component switchers available(locally or online). Just make sure it can handle HD bandwidth(30-40 MHz, I think?).
    DJ
  3. Tom Grooms
    Tom Grooms Second Unit
    Jul 17, 2000
    273
    You don't need to hook up your HDTV receiver with analog output's. Hook it to your TV through the DVI. Look at the Samsung T-151 and T-165's.
  4. Joe Ferreira
    Jan 17, 2003
    68
    Thanks for the info. My TV doesn't have DVI input. My Onkyo TX-SR500 doesn't switch component. Maybe I should sell it on eBay and pick up the SR600? How much do the component switches cost?
  5. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,788
    498
    9,110
  6. Jerry Dreiss
    Jerry Dreiss Stunt Coordinator
    Oct 13, 1998
    55
    You didn't mention which Samsung TV you got, does it have a VGA input? Some STBs still output VGA, so you could look into that.
    VGA, the forgotten input.
  7. Scott Merryfield
    Dec 16, 1998
    12,822
    1,371
    9,110
  8. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    You do not need to purchase a component switcher to pass a component signal.
    Let me repeat that, you do not need to purchase a component switcher to pass a component signal.
    You can buy a cheap composite $14-20 A/V Switcher from RadioShack or Wal-mart (Usually the kind in the Video Game section) and it will pass 1080i HD material. No loss in HD quality.
    The bad side is that these are manual switches and you will have to get up when you switch the signal. However, if you leave it on the HD Tuner all the time, you can then make the manual switch when you get up to pop in the DVD anyway.
    If you'd like a manual switch with Toslink (optical) digital audio, these can be had for around $39-49 from Radioshack.
  9. Chris S
    Chris S Cinematographer
    Apr 9, 2000
    2,539
    9
    110
    Chris S
  10. Steve Schaffer
    Steve Schaffer Producer
    Apr 15, 1999
    3,756
    Chris,
    They are mechanical switches and as such should have no problem with bandwidth.
    The Denon 3803 receiver achieves 100mhz component video switching bandwidth because it's a mechanical switch activated by solenoids.
  11. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
  12. Joe Ferreira
    Jan 17, 2003
    68
    Sweet, that switch sounds like it would do the trick until I get a new receiver.
    Now, about the HDTV receiver itself...What exactly can I expect? I am in Oklahoma City (not that you would know what we have here) and I have cable (Cox). Are there hidden HD signals in the cable, or will I need to use an antenna. Also, how much do they start at and what are the differences between the entry level and higher-end receivers? And how do the channels work. Thanks for informing a newbie. Joe
  13. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    Joe, for Oklahoma City, OK, the Over the Air digital channels you should be able to receive via an antenna are the following:
    KOCO-DT 7 ABC
    KTBO-DT 15 TBN
    KOKH-DT 24 FOX
    KFOR-DT 27 NBC
    KQOK-DT 29 IND
    KETA-DT 32 PBS
    KOCB-DT 33 WB
    KWTV-DT 39 CBS* (Awaiting FCC Permit)
    KOPX-DT 50 PAX
    I obviously can't verify these, but you can do a search on http://www.antennaweb.org for your local channels.
    You can also choose to get Dish or DirecTV for HD channels like HBO HD, Showtime HD, HDNet (DirecTV), Discovery HD (Dish), etc.
    You can check http://www.titantv.com for the daily offerings of HD content available.
