Looking for advice
Discussion in 'Beginners, General Questions' started by Nap, Jul 14, 2006.
  1. Nap
    Nap Auditioning
    Jul 13, 2006
    I've done some research and have come up with the following components for my home theater. What do you think? Any better alternatives?
    Projector: Panasonic PT-AE900U ($1799 w. $300 manufacturers rebate)
    Receiver: Denon AVR-3806 ($799) or AVR-2807 ($685), AVR-4306 ($1366)
    Screen: Carada Criterion Series w/Brilliant White Screen Price: $744 (100" HDTV screen)
    DVDPlayer: DVD-Audio/Video/SACD Player: Denon DVD-2910 Price: $578
    Speakers
    Front: Intimus 533-PT Powered Tower Speakers ($599 each)
    Surrounds: Intimus 422-LR Satelite Speaker ($100 each)
    Back Surrounds: same as above
    Center: Intimus 533-VAC Center Channel Speaker ($280)
    Subwoofer: Intimus S-10, 10" Powered Subwoofer ($499)
    Total for Speakers: $1279 $1778 with subwoofer
  2. wpgWiggum
    wpgWiggum Extra
    Jan 17, 2006
    16
    Although I don't have a projector, I've been reading on the forums here for a while and many members feel building your own screen is often well worth the trouble. I you already have a white wall, the cost is nothing...and can go up to a gallon or two of paint.
    If you don't like the painted wall solution, not much was wasted...but so much could be saved.
  3. Alon Goldberg
    Alon Goldberg Screenwriter
    Jul 10, 2006
    1,131
  4. BrianTwig
    BrianTwig Second Unit
    May 1, 2006
    252
    The only suggestion I can make is take a good look at the SVS PB10 for the sub. Maybe step up to the PB12.
    I just love my SVS sub and it is without question the best audio purchase I have ever made in my life. So I always recommend them. Take it for what it is worth. Free advice.
  5. DavidLim
    DavidLim Auditioning
    Nov 8, 2004
    12
    don't mean to diverge but where are you able to get the Denon 2807 for $685? Thanks
    David
