Looking for a repair/tech to help me out with laser pickups
Discussion in 'Playback Devices' started by Jeff D, Dec 30, 2003.
  1. Jeff D
    Jeff D Supporting Actor
    Apr 6, 1999
    604
    I'll be cross posting this in a few areas, I need an answer. Forgive me if you see several of these...
    The situation:
    The wife has a CD player that wasn't working I've got it narrowed down to a problem with the laser pickup. The part is an HOP-M3 (pretty old).
    The part arrived today and I had the wife install it. (that was fun) After all that the thing now *works*, but not perfectly.
    There's a couple of issues like audio cracks up sounding like white noise. My guess is a bad alignment/focus on the pickup.
    There is a zip file attached with 4 picutres, two are of the pickup and two are of the screw and springs used to hold the pickup & motor tray to the rest of the drive.
    First question... am I at risk of deadly radiation from running this thing without the cover? I have an 82 CD player that has warnings all over the inside to not operate without the cover on. Now every engineer I work with has CD/DVD drives in development boxes running with no covers. I don't remember if the denon has any warnings. I hope it's save.
    Second, in the screws pictures this unit was disassembled a month ago, I pretty much remember how this went together, but these screws&spring parts got me confused. the other side of the pickup/motor assembly seems to be flush with the rest of the drive. I thought these spring screws could be a shock for the pickup, but I'm not sure how well this is working.
    Lastly... what's the white part on the HOP-M3, can it be used to adjust the focus? If so... how? It seems every time you mess with the pickup assembly the whole pickup assembly can move around. I would think this is bad... is there a standard or parked position to use?
    The unit now will play some discs, but not all tracks. Then there's also the problem with not all disc working too.
    I hope someone can help me.
    Thanks!
  2. Jeff D
    Apr 6, 1999
    604
