Looking for a receiver.
Discussion in 'AV Receivers' started by Ryan JJ, Aug 9, 2004.
  1. Ryan JJ
    Ryan JJ Auditioning
    Aug 9, 2004
    3
    Hi,
    I have the SKS-HT240 Onkyo 6.1 speakers. I am looking for a receiver in the $300-500 price range, with Dobly Pro Logic IIx, and surround headphone support. The Yamaha RX-V550 seems perfect for my needs, but I don't where I can get it.
    Thanks!
  2. dustin r
    dustin r Extra
    Aug 8, 2004
    19
    why dont you look into the yamaha rx-v650 or the rx-v750. they both have the ypaoi feature (dont know if the 550 does) and the rx-v750 upconverts s-video/composite to component. try going to yamahas website and do a search for a local authorized dealer near you.
    [​IMG]
  3. johnSO
    johnSO Auditioning
    Feb 21, 2005
    Have you been able to listen to those speakers. How do they sound? Compared to maybe the ones that come with the 770?
  4. Tu Pham
    Tu Pham Auditioning
    Jan 29, 2005
    8
    You can find the right receiver here. www .hometheaterforum.com/htforum/search.php
  5. EvanW
    EvanW Stunt Coordinator
    Feb 22, 2005
    233
    Pioneer VSX-1014TX(same as pioneer elite VSX-52TX)300$ cheaper will put alot of receivers in its price range to shame.
  6. Kevin_F
    Kevin_F Stunt Coordinator
    Dec 1, 2004
    246
    I believe you can find the Marantz 5500 for $500
