Sacha_C
- Jan 13, 2003
I will be getting a projector as soon as I can afford one which should be in a few months hopefully. Anyway, I'd like recommendations and ideas of how much the bulbs will cost per hour.
I would like a projector that can accept a 1280x1024 signal (but 800x600 or 1024x768 native res) since that is what I use on my PC monitor and I won't want to chaneg the resolution each time I want to use the projector.
Is there a big difference in quality for DVDs between a 800x600 and 1024x768? Is it worth getting a 1024x768?
I would also like a projector with an "economy" mode that dims the lamp to increase it's life (I assume "economy" mode look fine when in total darkness?)
Could you please recommend a few projectors that would end up costing me less than $3000 US and that have a good per hour bulb cost?
