Looking for a good 10" DVC Driver
Discussion in 'Archived Threads 2001-2004' started by Jin E, May 22, 2001.
  1. Jin E
    Jin E Second Unit
    Nov 19, 2000
    452
    Subject says it all. I'm looking for a good DVC 10" driver (with decent Xmax) that I can make into a Home Theater sub. Anyone know of any?
    -Jin
    My Theater
  2. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    Is the ACI SV10 a DVC?????
    I haven't looked yet.
    Nice Xmax for 10"..
    There's also the MASS 10 and eVo 10"
  3. Ken Cline
    Ken Cline Stunt Coordinator
    Jun 30, 1997
    99
    Although it's a 12", I'd recommend the Dayton 12" DVC. XMax is 15mm. The specs are very similar to the Shiva.
    Ken Cline - Home Theater Fanatic
    [email protected]
    Friends Don't Let Friends Watch Crap!
    www.dvdtracker.com/~kencline.asp
  4. Fred Seger
    Fred Seger Stunt Coordinator
    Aug 13, 2000
    136
    Although it's not a DVC, the titanic 1000 from partsexpress does have a 12mm xmax.
    Personally, for HT use I would definately go with a 15", or at least 12" driver. Box size will have to increase but the results are worth it.
  5. Julian Data
    Oct 5, 1999
    408
    MASS 2010 series 19-20mm Xmax
    JD
  6. Nick O
    Nick O Auditioning
    May 20, 2001
    11
    Ever consider two larger drivers in a push pull configuration? Because they work together to move the same amount of air you need half the recomended box size of one driver and will lose half the distortion. The bad news is you need two drivers and they only reproduce the same amount of bass. I have had excellent results with 12"-21" drivers that would normally require huge boxes. Two NHT 1259 need only 1.8 ft3
    dayton makes a good dvc 15" with huge excursion and you could wire them to 8 ohms. Swan has a good cheap(60$) 12"also. good luck!
