Does anyone know who if any company is making a quality DVD recorder? By quality, I mean one that will play in my other DVD player and I can edit on my PC.
Thanks in advance,
Here's the scoop:
1. Panasonic's DMR-E20 records DVD-R & DVD-RAM. The former will play on most DVD players, but the latter only in PC DVD-RAM drives & DVD-RAM capable players like the RP91. You can edit on a PC w/DVD-RAM
2. Pioneer's DVR-7000 is a pricey DVD-R & DVD-RW recording unit. You can edit DVD-RW. DVD-R & DVD-RW discs recorded in 'Video Mode' will play on most DVD players
3. Philips' DVDR1000 & DVDR1500 are DVD+RW units (different from DVD-RW). Discs don't need to be finalized, you can edit anytime & play on most DVD players. Seems to be the most versatile all-in-one solution, but the +RW format is not sanctioned by the DVD Forum
It's anyone's guess as to which format or formats will win.
Thanks a lot,
I also did some research and looked at the Philips DVD Recorders. They're giving away a free DVD recorder here. Link Removed
The DVD+RW format seems to be the most compatible format and it says that they use an I-link(firewire) connection.
Works for me.
Todd
