looking for a decent inexpensive line doubler
Discussion in 'Archived Threads 2001-2004' started by Carl Longnecker, Jun 20, 2002.
  1. Carl Longnecker
    May 1, 2002
    16
    can someone reccommend an inexpensive line double or video scaler?
    hopefully that does inverse telecine, or am I asking too much?
    - Carl
  2. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Check into the Iscan. Dvdo product (Silicon Image), pretty much the best bang for minimal bucks- only doubles, but does a decent job.
    There have been 3 versions, V1, V2 and the Iscan Pro. Each has different features and chipsets-- might do some searching here and on AVS for gory details on each. I had a V2, and it would detect film sources and did 3-2 pulldown.
    http://www.dvdo.com/home.asp
    http://www.dvdo.com/dvdo/iscanpro.asp
    -Vince
  3. Carl Longnecker
    May 1, 2002
    16
    Wow, that's a bit more expensive than I was hoping for. [​IMG]
    I can justify that kind of cost to my S/O if I build one myself. I am going to buy a SiI504 chip, but I need an RGB to ITU-R BT.656 video decoder. The only video decoders that I can find only accept SVideo, composite and YPrPb inputs and not RGB.
    Since my projector uses RGB, I need RGB.
    Anyone know of an IC that does RGB to ITU-R BT.656?
    Thanks!
    - Carl
  4. Vince Maskeeper
    Jan 18, 1999
    6,499
    Wow, the Iscan is super cheap. I have never seen anyone see the ISCAN as too expensive (it was an absolute breakthrough when it was introduced, as it was $800 less than anything else).
    You might try the used market, I have seen the Iscan V2 sell for $300.
    -Vince
  5. Carl Longnecker
    May 1, 2002
    16
    I've already looked at ebay. Know of a better place to look?
    Besides, I'm still interested in building my own. Anyone know of an IC or ADC that converts RGB -> ITU-R BT.656?
  6. Vince Maskeeper
    Jan 18, 1999
    6,499
    Try posting about this on the DIY/Advanced board-- this type of question isn't too suited for the basics area. If no one on here can help- AVS forum might have a few tweakers that can help you.
    -Vince
