Looking for a component system to power 4 speakers and allow connectivity to my IPOD? (1 Viewer)
jdland22
Jason
I would have thought I was looking to do a fairly easy application, but I am not finding what I am looking for. I wired two outdoor speakers and two indoor speakers and I am looking for a receiver to power those speakers. I will not run any video or surround sound through the component. I would like the capability to run all four at the same time but then also be able to run just the 2 indoor or the 2 outdoor. I would prefer to not have to buy a big bulky AV receiver. And I want the option to hook up my IPOD to the receiver. Are there any component systems out there that will meet these needs and not break the bank...say less than $200.
Thanks for your help!
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
It's no problem finding a basic stereo receiver that will do the trick - just make sure it has a switch on the front for "A" and "B" speaker options, and make sure they can both be used at the same time.
The problem is your price range - not sure under $200 is realistic for a new component. I suggest checking your local pawn shops.
Wayne A. Pflughaupt
socker_dad
