Looking for a budget sub
Discussion in 'Speakers & Subwoofers' started by Jim517, Aug 7, 2019.
Tags:
  1. Jim517
    Jim517 Second Unit
    Apr 11, 2014
    435
    76
    110
    Summit, Wisconsin
    Jim
    I'm looking to buy a 12" sub for 75% home theater and 25% music. Budget about $250 or less. What do you guys recommend? I thought about these.
    1) BIC PL200 II
    2) BIC F12
    3) Dayton Audio 12"
    3) Premier Acoustics PA-150
  2. John Dirk
    John Dirk Cinematographer
    May 7, 2000
    2,844
    1,072
    4,110
    ATL
    JOHN
    I took a quick look and all of the candidates on your shortlist are highly reviewed on Amazon but, generally, with a caveat similar to "great for the price." Be careful. You alluded in a previous post that you already own a sub so I assume it is either damaged/dead or you're looking for better performance. If I'm correct then my advice is to wait until you can spend a bit more and consider this one, or maybe two of them.
    https://rslspeakers.com/products/rsl-speedwoofer-10s/
  3. JohnRice
    JohnRice Executive Producer
    Jun 20, 2000
    12,314
    1,976
    9,110
    A Mile High
    The BIC F12 is actually pretty decent.
  4. Message #4 of 7 Aug 8, 2019
    Jim517
    Jim517 Second Unit
    Apr 11, 2014
    435
    76
    110
    Summit, Wisconsin
    Jim
    Thanks guys. This is to replace a 8" Sony sub in our family/TV room.
    The RSL Speedwoofer gets great reviews, but I don't know if I want to spend that much.
    Any other recommendations ?
  5. John Dirk
    May 7, 2000
    2,844
    1,072
    4,110
    ATL
    JOHN
    Just curious. Is there anything wrong with the Sony or are you just looking for better performance?
  6. JohnRice
    Jun 20, 2000
    12,314
    1,976
    9,110
    A Mile High
    The BIC F12 or the Dayton 12" really seem to be the best choices in the under $400 range.
  7. Jim517
    Jim517 Second Unit
    Apr 11, 2014
    435
    76
    110
    Summit, Wisconsin
    Jim
    Looking to upgrade from the Sony.
    John Dirk likes this.
