Looking for a 2 channel amp (1 Viewer)
MikeHalder
I am looking for a 2 channel integrated amp for a pair of Infinity Outrigger outdoor speakers. I plan on using the ' second zone' output to run the amp and need some input on what you guys would recommend for this application.
TIA,
Mike
RichardMA
The sound from those speakers is not great, since it's outdoors it will be even less critical. Try Ebay for
cheap but reliable amps from Rotel, Adcom, B&K, etc.
50wpc should be fine.
Jquick80
