Looking for 5 channel amp. (1 Viewer)
Dan_C
I'm in the market for a 5 channel amplifier in the 120 to 175 watt per channel range (into 8 ohms).
Some of the models I have thought about:
Marantz MM9000
Rotel RMB1075
Outlaw 750
Want to pay less than $800
Thanks!
Dan_C
Gary,
Your link doesn't work. How 'bout another link or at least what 5 channel amp you are willing to sell so I can look it up elsewhere? Thanks for responding man.
Jerry Klawiter
Dan,
I have 5 extra channels of these SoundStream THX mono amps.
I purchased many of these a year or so ago in a buy out.
I use these myself and love them.
I have one Brand new sealed M3 and an open box M2.
I would like $160 per channel plus shipping.
The speakers I'm using them with are:
Paradigm Ref 60's v2
Ref CC
Ref 20's v2
Here are a few spec's:
*Lucasfimlm THX certified for home theater use
· Low Impedance/ High Current Design
· Balanced/ Unbalanced Input with XLR and Gold RCA inputs
· 6-Gauge, Gold 5-way Binding Posts
· Accessory Link (+5 volt remote turn on capability)
· Intelligent Short Circuit Protection
· Audiophile grade removable AC Line Cord/ Fuse Holder and the Cordlox cable management system.
Specifications per channel:
·FTC Power Rating 120W @ 8 Ohm < .05% THD, 20Hz-20kHz Very Clean!!!
Maximum Power
160W @ 8 Ohm
270W @ 4 Ohm
300W @ 3.2 Ohm
·Signal To Noise 113 dB (A-Weighted @ 120W)
Voltage Gain 28.28x
Frequency ·Response 20Hz-20kHz (+0dB, -0.5dB)
Bandwidth 3Hz-75kHz (+0dB, -3.0dB)
Input Sensitivity 1.1V (120W @ 8 Ohm)
Input Impedance 10 kOhm
Input Connectors 3-pin XLR, RCA phono
Slew Rate >30V
Damping >350
Power Supply High Flux Toroidal.
That would be One Toroidal in each channel, not shared.
Dimensions
M2/M3 5.75" x 17" x 16"
Weight
M2 28.2 lbs
M3 41.8 lbs
That's 70 lbs for five channels!
Let me know if your interested. :emoji_thumbsup:
Jerry
John A. Casler
Have a brand new (maybe 4 hours on two channels) Carver 705x THX certified 5 channel amp.
125 x 5 @ 8 ohms
$699 plus shipping
John Casler
Robert Ray
Hi Dan,
This might be a little over your budget but I have a Golden Theater GTA-1 five channel amp. 200 watts per @ 8ohms and 400 @ 4ohms.Asking 850.00 plus shipping.
Also have the GTX-1 pre/proc. with upgrade if interested.Both excellent condition with box and manual.RobertRay
Dan_C
Robert-
Yep; a bit out of my budget but thank you!
Still looking if anyone has a 5 channel 125-175W per channel amp their looking to sell.
Mark R O
Dan,
Have a Parasound HCA-1205, doubt that it has a hundred hours on it.
140 wpc 8ohms
200 wpc 4ohms
45 amps current output - per channel!
1.6 kVA Transformer, 100,000 mic supply
John Curl design, THX Ultra Cert. (big wow.)
All the Best,
Mark
