Looking for 1080i DVD player
Discussion in 'Playback Devices' started by Marc_Sulinski, Jan 13, 2004.
  1. Marc_Sulinski
    Marc_Sulinski Supporting Actor
    Jan 15, 2001
    559
    110
    I am looking to get a DVD player that ouptuts 1080i so that my TV's (Hitachi 57XWX20B) internal scaler will not upconvert the 480p signal to 540p. I am currently using a Toshiba SD5109, and I notice a lot of dithering of reds on my TV, and I am hoping to fix this by bypassing the scaler.
    I considered the Samsung model, but a lot of people seem to have audio synchronization issues. The Denon 5900 ($2000)is way out of my price range, which is about $3-400. I would prefer something without the chroma bug, as this may also be the cause of my problem.
    I am not positive that the problem is in the scaler, but I would at least like to try, as it is really annoying. If anyone has recommendations on DVD players or what the display problem might be, I would appreciate it.
  2. Andre Bijelic
    Andre Bijelic Stunt Coordinator
    Feb 10, 2000
    193
    In order to receive a 1080i signal from any DVD player on the market, your set must be equipped with a DVI connection which is capable of accepting copy-protected signals. No one makes a player that upscales to HD through the component inputs.
    I believe the only players that upscale are the Samsung 931, the Bravo D1, the Liteon LVD 2001, and the LG DV7832.
    Keep in mind, though, that unless you have a LCD, DLP, plasma, or other truly "digital" display, you probably won't see a benefit from using the DVI connection. I have a 46", rear projection, CRT Sony and I tested out the Samsung 931. The picture actually looked worse through the DVI than it did in progressive scan through component.
  3. Brajesh Upadhyay
    Brajesh Upadhyay Supporting Actor
    Jul 11, 1998
    787
    If you have a DVI input, the Momitsu V880 (regionfree & Macrovision-free) delivers steller video. Look @ avsforum.com for more info. This player also has component output for 720p/1080i, but the picture is soft. If you don't have a DVI input, the best player is the now-discontinued LiteOn LVD-2001 (look @ eBay). It delivers very good picture via component.
  4. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    If you truly mean that no one makes a player that upscales to HD, you are correct.
    If you mean that no one makes a player that upscales to 1080i through the component inputs, you are mistaken. See the Liteon 2001 (although, even there, you are technically correct since it's out of production)
