Long interconnects vs long speaker wire?
Discussion in 'Archived Threads 2001-2004' started by David Barteaux, Jul 16, 2002.
  1. David Barteaux
    David Barteaux Stunt Coordinator
    Jan 6, 2001
    179
    Which will give better results? Longer unbalanced interconnects or longer speaker wire? High end cables not applicable.
  2. David Barteaux
    Jan 6, 2001
    179
    Moving this question to Tweaking & Connections area.
  3. John_W_Jr
    John_W_Jr Stunt Coordinator
    Jul 7, 2002
    67
    David,
    Here's the response that a Stereophile commentator got when he posed that exact same qustion to a panel of cable makers (and I can vouch, cause I was there): Cable guy #1 -short interconnects, long speaker cables; Cable guy #2 -long interconnects, short speaker cables; Ray Kimber (of Kimber Kable) -long interconnects...and long speaker cables!
    I believe that the electrical wisdom is that if your running un-shielded interconnects--keep 'em short because the signal is small and susceptible to noise. However, I myself run 20 feet of Kimber PBJ, a non-shielded, but braided (twisted) interconnect over to my amp with no problem. My speaker cables are 8 feet and are a bi-wire configuration.
    If your interconnect and speaker cables are composed of twisted wire, which helps to cancel and reject noise, you should be able to run whatever is most convenient for you. The speaker cables I use are way more expensive than the interconnects, so for me it made $ense to run longer interconnects...also, the amp looks kool sitting on the floor in between the speakers. [​IMG]
    Hope that long essay helped!
  4. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    I believe someone asked this exact question not too long ago. Have you tried searching the archives of the Tweaks/Connections forum?
  5. Justin Doring
    Justin Doring Screenwriter
    Jun 9, 1999
    1,467
    I would keep the interconnects short (1 or 2 meters) and the speaker cables long.
  6. Hyun K
    Hyun K Stunt Coordinator
    Apr 18, 2002
    80
    Here's a direct quote from cheksy's website (chesky.com)on the topic:
    Learning Library
    Cables & Bi-Amping
    George Kaye
    "Is it better to use long interconnects and short speaker wires or vice-versa? My experience has shown that under most conditions it is best to keep the power amplifiers close to the speakers so that speaker leads can be as short as possible. Adjust the interconnect length form your preamplifier to your power amplifier accordingly. The reason for this is that the amplifier needs an unrestricted path to the speaker in order to fully control the speaker motion. Speakers are motors and motors generate a back voltage." That voltage is what the amplifier senses with it's negative feedback loop to determine the instantaneous motion of the cones. Long leads with higher resistance and reactive components mask that information from the amplifier. The result is usually a loss of bass definition and control, smearing of the instruments in the soundfield and a veiling" of the sound.
    The length of all wiring should be minimized for best performance. Most high-end preamplifiers can drive a 20-foot pair of interconnects easily, but excessively long interconnects load a preamplifier's output and can result in high frequency loss. Passive" preamplifiers are especially prone to this because they have no circuit that specifically drives long lines."
    "It is better to use one long interconnect from the preamp to the amp and split the signal with a Y" splitter to both channels. This keeps the cable loading on the preamp to a minimum."
  7. Mark Tranchant
    Mark Tranchant Stunt Coordinator
    May 9, 2002
    126
  8. Hyun K
    Apr 18, 2002
    80
    FYI, The last quote on there was about biamping. don't know why I stuck that one on there.
  9. Lee Scoggins
    Lee Scoggins Producer
    Aug 30, 2001
    6,394
    Lee
  10. Mark Tranchant
    May 9, 2002
    126
    Lee - I appreciate the guy's pedigree, but the quote outside its original context seems to suggest throwing away one of the stereo channels to reduce cable loading on the preamp. No matter who says it, that is ludicrous.
    Now as Hyun explains, the quote actually refers to bi-amping and reducing the total cable length by splitting at the far end: this is reasonable.
  11. Lee Scoggins
    Aug 30, 2001
    6,394
    Lee
    Mark,
    George would not ever suggest throwing away a channel! would be self-defeating no? The quote is from some other, unrelated area.
    The question is really one of interconnect degradation versus speaker cable. On this, I believe George is right based on personal listening experiences and trying configurations in the recording studio. This does create problems for HT setups, however since you need long wires in places.
    Another benefit from George here is that high end speaker cable is often more expensive than interconnect so you save money that way. Of course, you don't want to be too far away...
