Logitech X530 (1 Viewer)
Jaromir
Hi Guys,
I have a small room and I want to set up a surround sound for my DVD. I have the Panasonic DVD-S27, which has a digital audio out through coaxial. Can I use the Logitech X530 without going through Dolby receiver? If not, which surround PC set could I use? I can't go crazy on sound because of my neighbors, but want a good quality. Thanks, Jaromir:frowning:
John S
Gotta link to the Logitech product, I did a quick search and came up empty.
ScottCHI
HERE
from what i can tell, you will NOT be able to connect these digitally. and you'll need an adapter to connect to the L+R analog outs of your dvd player. and then it looks like you can only utilize a "matrix" feature to get the sound into all the speakers.
THIS link is probably pertinent. these speakers are similar. read about connecting them to an Xbox, PS2, or DVD player.
THIS set up WILL work.
thebox
