Logic 7 versus DPL-II : How do they differ? Which is better?
Discussion in 'Archived Threads 2001-2004' started by John Morris, Sep 23, 2001.
  1. John Morris
    John Morris Guest
    I have been waiting for the release of the Outlaw 950, which has DPL-II but now have an opportunity to buy a Lexicon DC-1 with Logic 7 at a very good deal. If we just consider the Logic 7 format versus the DPL-II format, which is better for HT playback of stereo and DPL encoded discs. Which is better for playback of stereo CDs?
    Which would you prefer and why?
    Thanks!
    Take Care,
    merc
    [​IMG]
    God Bless America!!!
  2. Randy G
    Randy G Second Unit
    May 18, 2000
    460
    They both attempt to do the same thing, but the primary difference is that Logic7 can be be scaled to use 7 channels while DPLII can only do 5. That's the major difference. I truly feel that Dolby should have made DPLII scalable to 7 channels(they probably will do so at some point anyway, for marketing reasons) to compete with the likes of Logic7 or Meridian's TriField.
    Also, make sure that that DC-1 has the most current version of Logic7....although it WON'T have the "new and imroved" version of the MC-12.
  3. dougW
    dougW Stunt Coordinator
    Aug 14, 2000
    241
    Another distinct difference in logic 7 and DPL II is that L7 is designed to operate with discrete 5.1 sources, as well as matrixed sources. That's across the board from the DC-1, DC-2, MC-1, to MC-12.
    Pitfalls of the DC-1 is it's an aging chassis with limited support from Lexicon at this point. Don't expect the see the bells and whistles made available for eprom upgrades of the units above it. Also, 2 channel performance is not on par with the MC-1. DC-2 is probably closer to the DC-1 in that regard than the MC-1.
    No comment in comparison to the Outlaw. The DC-1 is an admirable performer, and certainly gives you a lot of flexibility, as remember, it used to be the flagship at one time. That day has come and gone though.
    Lex
    Lexman's Theater
  4. Jeremy Anderson
    Jeremy Anderson Screenwriter
    Nov 23, 1999
    1,049
    I can't remember where (maybe AVS Forum?), but I recall Jim Fosgate saying that DPL2 has been specced out for 7 channel and no one has implemented it as of yet. So perhaps in the future, we'll see that happen.
    As for DPL2 vs. L7, I've heard both... and I preferred DPL2. Logic 7's placement of sounds sounded too artificial in comparison to DPL2's natural smooth transitions and placement between channels. But hey, that's just my opinion...
  5. Earl_C
    Earl_C Agent
    Feb 13, 2001
    40
    "DC-2 is probably closer to the DC-1 in that regard than the MC-1"
    The DC-2 and MC-1 are sonically identical.
