Lock on "FULL" mode
Discussion in 'Archived Threads 2001-2004' started by scott cerv, Jan 17, 2003.
  1. scott cerv
    scott cerv Stunt Coordinator
    Mar 26, 2002
    51
    What exactly is this?? I recently got a DV45a and the 2.35:1 movies got larger than they were previously on a Denon 1000. I have a Mits 55511. I set the 45a up for a16x9 tv and the picture got larger than we previously saw, but if I set the player for a 4:3 screen I see the same image as before. The image doesn't fill the entire screen and I realize it shouldn't, but do I have a problem??
    SC
  2. Scott Merryfield
    Dec 16, 1998
    12,624
    1,281
    9,110
    Some 16x9 TV's (including Mitsubishis) will not allow you to use different viewing options when the TV is receiving a 480p video signal. Instead, the television locks into FULL mode (or whatever the manufacturer calls the mode used for viewing anamorphic DVDs). Your options for viewing non-anamorphic widescreen material in this case are (1) switch to interlaced video mode, (2) buy a progressive scan DVD player with built-in scaling features, such as the Panasonic RP-91, or (3) watch a smaller picture that is both letterboxed and windowboxed.
    Incidently, my Toshiba 56H80 does not lock into FULL mode on a 480p signal, but it does with a 1080i signal. In this case, my HD tuner must handle any viewing mode adjustments.
  3. ManW_TheUncool
    ManW_TheUncool Producer
    Aug 18, 2001
    6,015
    40
    6,610
    The BK
    ManW
  4. Grant H
    Grant H Cinematographer
    Jul 24, 2002
    2,844
    Well,you can do #3 if you switch to interlace. In which case #1 should read switch to interlace and use TV's Zoom, and #3 would read switch to interlace( and keep TV in normal which won't stretch the picture)
    I understand this isn't so easy for some players/tv combos though since some players only have the switch for I/P on the back and some TV's have separate inputs for Interlaced and Progressive. Sove players may have separate outputs too (don't know about that one though)
  5. ManW_TheUncool
    Aug 18, 2001
    6,015
    40
    6,610
    The BK
    ManW
    Gotta love all the extra complexity that aspect ratio control throws into the whole mix of things, no? [​IMG]
    Makes me feel pity for J6P and his desire to simply fill the whole screen at all costs. [​IMG] It's tough enough for most people to learn about OAR as it is...
    _Man_
  6. Seth Paxton
    Seth Paxton Lead Actor
    Nov 5, 1998
    7,585
    Well, there are also some players that don't really "scale" the image when it is a 4:3 source going to a 16:9 monitor (as set in the DVD players menu of course), but instead will create a true 16:9 image by adding black video bars on each side.
    That way when you have a P signal going to a set that will automatically fall into FULL mode with a P signal, then you will always get the correctly sized image since the DVD player will always put out a 16:9 image even if it has to add the bars to the sides of the 4:3.
    In fact, IIRC most manufacturers of TVs that lock on Prog signals also happen to make players that will create 16:9 images from 4:3 ones. I think RCA and/or Pioneer had/has players that do this, for example.
  7. Allan Jayne
    Allan Jayne Cinematographer
    Nov 1, 1998
    2,404
    I still think it is worth staying away from a TV that locks in 16:9 mode. If you buy one you will be cursing at it soon thereafter.
    Try the aspect ratio modes using the remote in the store before buying. Use a variety of source material including HDTV.
    When the DVD player has to format the picture and add the black side bars, the video cable needs to be of a higher quality (higher bandwidth).
    Video hints:
  8. Mark LP
    Mark LP Agent
    Nov 18, 2002
    47
    I have a Mitsu TV and I can select from all size formats when viewing 480p signals. If I'm watching a movie for the 2nd or more time and dont feel like adding to the burn in on anamorphic dvds, then I zoom the picture in.
    Mark
