If I get a Direct TV HD Receiver and get the local package, do the local channels not come in HD? It seems like they would since they are broadcast in HD?
No you will not get them via the satellite. I have heard rumors that DirectTV will be adding HD Locals but nothing concrete. Also dont be confused, the HD channel is a seperate broadcast and station number from the normal network station so just because you receive one does not mean you receive the other. If you are physically close enough you may be able to receive the HD Locals via an OTA (over the air) antenna. Check www.antennaweb.org for recomendations.
It has been announced. The SpaceWay satellite will be launched in the spring. My guess is that they will start with the top 20 markets and work their way down. It will require another dish and some HD receivers will not be compatible with the new equipment.
