Little help finding what I need...
Anthony Moore
I am running speaker wire from an amplifier in my main control room to a volume control box in each bedroom, then to the each of the speakers in the ceiling.
So all I need is an in-wall volume control. Unfortunately all I can find out there are round knobs and a few (up and down) sliders. What I would really like is something like i have for the lights in my room (a dimmer). It has up and down buttons and lights along side of it to show the level.
I dont know if anything out there like this exists for volume control, but I really dont want a round knob or slider. Anyone find anything else that looks good, even if it isnt what I described, I would appreciate it very much for a link or a brand.
edit: it cant be RJ-45, cause all I have is the speaker wire running.
Anthony
homthtr
Steve
I've bought volume controls from just about every manufacturer that make them. You've found the 2 styles that are available. Knobs and Sliders.
Unless you make the move up the Keypads (yes the cat5 that isn't there) there's no other style of standard volume control made.
Everything else runs on Cat5
ArtW34
