little advice on audio chioces (1 Viewer)
netgun
kevin
I am new to the Home theater concept, but after a little research i have purchased an Epson 1080p UB and a 106 fixed screen. My next issue is the audio. I am looking for something in the sub 1K range, more than willing an expect to update components over time, but need a base to start from that provides reasonable sound. My room is not setup yet but is 14 x 14 and the seating will be 11 to 12 from the screen, if this matters.
thanks
netgun
kevin
There about, if that isn't realistic where do you suggest a base system starts at?
I picked 1K only becasue (a. keep cost down) and (b. there were packages under that amount, Sony, yamaha, etc.).
Again I may be wrong as well in the idea of an entry level or base system that i can upgrade.
Feel free to set me in the right direction.
thanks
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
I suggest you look at the Onkyo systems. Although the speakers are not that great (no HTiB has great speakers), the receiver is decent. The newer ones decode the latest high def and will handle better speakers in the future.
If you can up your budget a few hundred dollars, check out the SVS SBS-01 speakers for 1K. Add a lower end Onkyo for $300 and you will have a nice setup. The SVSOnkyo approach will fill your room much better than a HTiB can.
SVSound - Complete Systems
Amazon.com: Onkyo TX-SR606 7.1 Channel Home Theater Receiver (Black): Audio & Video
Onkyo HT-S9100THXB - In Stock at OneCall.com
PS - This should be your starting point. Don't take my recommendations as gospel. Do your own research and listen to as many options as you can in your budget.
netgun
kevin
Thanks for the help. After taking your advice and looking at my options and listening to a ton of speakers, including finding a local member with an SVS setup i have come to a final setup. Now that i have all the pices the setup fun begins.
Onkyo 806
SVS speakers
SVS Sub
Epson 1080 UB projector
106 screen
David Willow
Babbling Idiot
Mechanicsburg, PA
Dave
Sweet. Welcome to the highly addictive world of HT. You start with a budget in mind, and it increases every couple days until you finally just go for it.
Let us know how you like your new setup.
Mindy
