Lite-ON CD-RW Drives
Discussion in 'Archived Threads 2001-2004' started by AllanN, Apr 3, 2002.
  1. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
    Im thinking about getting a new CD-RW to replace my old 2x burner. Has anyone out there had any experiene with the Lite-On 16x EIDE drive?
  2. Brian E
    Brian E Screenwriter
    Aug 12, 2000
    1,636
    Lite-On makes very good drives. Drives from a lot of other manufacturers are rebadged Lite-On's. The 16X is a good drive in my experience, I don't have one but I've installed them for five different people and they are all happy. Can't beat 'em for the price. Their new 40X drive is nice too.
  3. Duane R
    Duane R Second Unit
    Mar 30, 2002
    307
    2
    110
    Although my preference runs to Plextor, Lite-On makes decent budget priced burners. Whichever model or brand you go with, make sure it has "Burn-Proof" (eliminates coasters).
  4. Brian Ooten
    Brian Ooten Extra
    Mar 25, 2002
    16
    The liteon driver incoporate features that current plextor/Teach/Etc.. runs do NOT include(correct ECM encoding(safedisc2)). As far as burners are concerned, the lite ons are as good as they get.
  5. Glenn
    Glenn Stunt Coordinator
    Oct 26, 1998
    229
    Hi Allan,
    I have the 24X Lite-On drive and it is great. No problems at all for me. Why get the 16 speed one when you can get the 24 or 32 speed for under $100? You can always use a slower burning speed with the faster drive but you cannot go faster with a slower one. [​IMG]
    My only complaint about the Lite-On CDRW is the lack f a good manual. However I can happily say that I have not needed one. Plus it came with Nero burning software which works great with Windows XP.
    Try www.newegg.com for great prices and fast shipping on Lite-On Drives.
    Glenn
  6. Chris Demaree
    Chris Demaree Stunt Coordinator
    Nov 3, 2000
    108
    I have a Lite-on 24x10x40x cd-r/rw. It works perfectly with winxp and came with Nero and Burnproof. Cheap too.
  7. Rob Varto
    Rob Varto Supporting Actor
    Mar 5, 2000
    711
    Im using a 16X Lite On burner myself... couldn't be happier.
  8. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
    I also have a 24x10x40x Lite-On CD-RW drive, and it's a nice performer. I've also found the bundled Nero to be a nice piece of software, and I do use this drive/software combo regular and it hasn't failed me (except due to user error).
  9. Rusty Ray
    Rusty Ray Second Unit
    Jun 26, 1999
    273
    i have the same 24x burner and couldn't be happier..
  10. Rob Speicher
    Rob Speicher Supporting Actor
    Nov 24, 2000
    935
    I have a 24x10x40 Lite-On and I've been mostly happy with it. It's an OEM model and sometimes "wigs out" and won't be recognized by the BIOS. Supposedly this is a problem with noisy power supplies or something - it only happens like 1 in 15 reboots, and I don't reboot often.
    My friend with the same model, only the Retail version has never had these problems, so spend a little extra and get the retail. Other than that I highly recommend them.
  11. Steve Russell
    Steve Russell Stunt Coordinator
    Sep 10, 1999
    131
    I installed a lite-on 24x10x40 in my Mac G4 and it has been a wonderful piece of equipment. Much cheaper than the usual drives that are advertised as mac-compatible, and much quieter than the dvd-rom that came in the computer.
  12. Travis Olson
    Travis Olson Supporting Actor
    Oct 7, 2001
    937
    Travis Olson
    Personally, I don't have a Lite-On burner, I have a Phillips. But if you are looking for a good deal on one check out this link. Dell has a 40x12x48 CDRW for $89 shipped. I have not checked this out, I just noticed it on that website. Happy hunting.
  13. Shiva Singh
    Shiva Singh Extra
    Nov 27, 2001
    24
    I've had a lite on 24x for a few months, and have been completely happy with it. I've routinely burned 10-12 discs in a row at 24x (16x Imatation media) with no problems at all.
    If speed is a concern for you, then by all means get the 40x burner. It's not that much more expensive, but it's only about a minute faster for cd-r compared to a 24x burner. The big feature IMHO is the faster cd-rw speed (12x). As someone who backs up a lot of data, it adds up.
    Rob Speicher, I had a similar problem with a computer that did this. It turns out the problem was with the other device attached to the EIDE channel. When I replaced that drive, the cd-rw worked perfectly again.
  14. Rob Speicher
    Nov 24, 2000
    935
