list of receivers and their bass management capabilities
Discussion in 'AV Receivers' started by Mike SJ, Jun 14, 2004.
  1. Mike SJ
    Mike SJ Supporting Actor
    Nov 10, 2003
    718
    It seems as though bass mgmnt is still a mystery to everyone including the manufacturers. There is no standard, there is no one way that will make everything better either. but there doenst even seem to be a list of who has what?! therefore, Ill try to make a list in the first post of receivers/pre-pro's with their BM capabilities.
    I dont know of any currently, but it would be best if you knew what your receiver/pre-pro did, then posted it here. I will try to consolidate what is posted back in this initial first post.
    cheers
  2. Mike SJ
    Nov 10, 2003
    718
    wow 53 looks and no one knows enough to post what the specs on their BM is...
    I assume the higher end market units have an adjustable xover, ive seen them increment at 5 hz from 50 to 100 or something like that. The lower end ones like mine, have a fixed point which really sucks if you have a good sub cause IMO, you shouldnt hear where the sub is coming from.
    My little pre/pro is set at 100 hz, which sucks and when my mains are set to small, it goes up to 120 hz which really sucks, but in my small apt, it really doesnt matter that much.
    I guess the point of this post is to see what options in BM are desireable. if you got to design your own sub xover, what whould you want on it? phase control?, 30Hz boost?, 5hz incremental x over point from 30hz to 100 hz?, thats about all I can think of, anyone else??
  3. Mike SJ
    Nov 10, 2003
    718
  4. Tod Golden
    Tod Golden Stunt Coordinator
    May 3, 2003
    82
    Not sure if this is what you're looking for but I'll bite.
    My Pio VSX-810 crossover points are 100, 150 and 200. However, when using the analog inputs for DVD-A and SACD, this option is bypassed. Therefore I have to rely on the players ability to handle BM. (563A)
    Tod
  5. Tod Golden
    May 3, 2003
    82
    Tod
  6. Mike SJ
    Nov 10, 2003
    718
    YES, its exaclty what i was looking for. just trying to get pros/cons for every type of BM. hopefully a manufacturer rep will read this...hopefully they can read [​IMG]
    "My Pio VSX-810 crossover points are 100, 150 and 200"
    again, it seems as though these are way way too high for today's new and improved HT subs.
    "However, when using the analog inputs for DVD-A and SACD, this option is bypassed. Therefore I have to rely on the players ability to handle BM." I dont think there is any BM for those formats. but i could be wrong
  7. Mike SJ
    Nov 10, 2003
    718
  8. aaron campbell
    aaron campbell Second Unit
    Jan 11, 2000
    281
    My HK 525 has triple crossover settings. You can set front, center,& surrounds individualy at 40,60,80,100,120,200. Also digital bass management for the analog imputs for dvd audio/sacd.
  9. aaron campbell
    Jan 11, 2000
    281
  10. Alan Wise
    Alan Wise Stunt Coordinator
    Jan 28, 2004
    236
    My Denon AVR-3805 has the follwing crossover frequencies:
    40, 60, 80, 100, 120, 150, 200, and 250 HZ.
    Al. Wise
  11. Alan Wise
    Jan 28, 2004
    236
    Al. Wise
  12. Andrew__H
    Andrew__H Auditioning
    Jun 12, 2004
    5
    My Rotel 1055 has adjustable crossover points at 40, 60, 80, 100, 120, etc.
  13. Andrew__H
    Jun 12, 2004
    5
  14. Mike SJ
    Nov 10, 2003
    718
    heck, maybe I just need to upgrade....*cough* *cough*
    I think im coming down with something....
    But for a $130 pre/pro, you cant really complain.
  15. Mike SJ
    Nov 10, 2003
    718
  16. Dean Wette
    Dean Wette Stunt Coordinator
    Jan 12, 2003
    97
    Arcam AVR300: xover from 40-130 Hz in 10 Hz increments
  17. Dean Wette
    Jan 12, 2003
    97
  18. Shiu
    Shiu Second Unit
    Feb 18, 2003
    447
    Sony STR-DA4ES - 40,50,60,70,80,90,100,110,120,130,140,150,160,170, 180,190,200. Each of the front mains, center, surrounds, surround back, and the subwoofer can be set differently.
  19. Shiu
    Shiu Second Unit
    Feb 18, 2003
    447
  20. Chris Brock
    Chris Brock Second Unit
    Sep 13, 2003
    328
    the yammy HTR-5760 has selectable 40, 60, 80, 90, 100, 110, 120, 160, and 200hz. you cant select a differnet setting for each speaker but you can turn the xover off and on for each speaker. you can also adjust the LFE output to sub only or both the sub and mains.
