Linux: clock trouble
Discussion in 'Archived Threads 2001-2004' started by Bill Catherall, Nov 20, 2001.
  1. Bill Catherall
    Bill Catherall Screenwriter
    Aug 1, 1997
    1,560
    Having recently installed Linux Mandrake 8.1 I've been having a bit of trouble with the clock. For some reason Linux insists that the hardware clock is set to GMT. So when I'm using the KDE GUI the clock is 8 hours behind (having set the time zone to PST). If I correct the time then it changes the hardware clock. The solution: Change the hardware clock to GMT. The problem: I'm running a dual boot system and the clock in Win98 uses the same time as the hardware clock, regardless of time zone. So either the clock in KDE is wrong all the time or the clock in Windows is wrong all the time.
    When I use the Gnome GUI then it's easy to fix because I just set it to read the GMT time and it shows the hardware clock time. But KDE doesn't have this ability. I'd have to set the timezone to be GMT. I'd do that but you have to select cities from a list. You can't just select a timezone and I can't find a city on that list that is in the GMT timezone! I'd hate to abandon KDE just because of the clock, is there some solution to this madness?
  2. Alan Curry
    Alan Curry Agent
    Aug 5, 2001
    47
    Try setting the clock through DrakConf i.e. Mandrake Control Central. It should ask you if your clock is set to GMT. Select no. To set the time zone, select a city within your time zone.
    Hope this helps.
    Alan
  3. Bill Catherall
    Aug 1, 1997
    1,560
    Thanks Alan. I'll give it a try when I get home tonight.
  4. Alan Curry
    Alan Curry Agent
    Aug 5, 2001
    47
    Bill
    I was wrong above. It should ask for the GMT after you have selected your city.
    Alan
  5. Bill Catherall
    Aug 1, 1997
    1,560
    Yep, that's what it did and it fixed the problem. I didn't even think of using the Mandrake Control Center. I was just using the KDE Configuration control and that wasn't giving me the option of turning off hardware GMT time.
    Thanks again.[​IMG]
  6. Alan Curry
    Alan Curry Agent
    Aug 5, 2001
    47
    Bill,
    Great! Glad to hear it. I'm glad that worked for you.
    Have a good evening.
    Alan
