Linon king 2 Simba Pride ?? DTS ES ? (1 Viewer)
Amazon say yes !!! but i buy and don't get any DTS ES on it !!! any clue ??? Matrix at least ? or i have to fooling myself and giving matrix 6.1 ES manualy in my remote for make DTS only to DTS ES the Amazon tipo !!! ?
And Cold Montain and a lot of tittle like that !!! Danger buying from online store who not the give the true detail !!! why they not put all DTS in DTS ES Matrix in DVD they sell if we have to do it manualy.
Artur Meinild
Amazon is not amazingly accurate re: disc specs, I would advise that you confirm with other sites such as dvdempire.com first. Beside that, some discs are not flagged properly, in which case you must apply EX encoding manually (yes it is dolby EX decoding even on DTS, unless it is DTS 6.1 ES discrete). Hope that helps, and hope I understood your post correctly... :)
TheThrillisgone
