Ed Isenberg
- Sep 10, 2001
I am in the planning stage for installing a new HT, and have a question/problem. My HT will be on one end of the house, while the bedrooms and balcony is on the other side, separated by a high-ceiling Great Room w/o attic. Installing remote speakers in the Great Room for background music (second input channel) isn't hard because there is attic access to one wall.
However, there is no easy way to get to the other side of the Great Room to wire the rest of the house for background music. My thought is that I already own two sets of RCA wireless speakers, so all I need to do is get the Line Out to the far side of the house. Then I can plug the dual RCA plugs into the wireless transmitter and place the speakers where I want them. (location will change depending on the season and whether I want a balcony vs. another guest bedroom wired).
My question is, how far can I run the Line Out leads between the receiver and the RCA transmitter? I'd have to go outside and it would probably take 100 feet of cable. If I remember correctly the line-out plug is designed for high-impedance short distances, the opposite of speaker wire which is low-impedance and great for long distances.
Does anyone have an idea? I would really like to make this solution work since it would be much more flexible and save me a ton of money over buying two pair of new speakers that then must be permanently wired.
Ed
Ed
