Lilo & Stitch - Widescreen OAR?
Discussion in 'Archived Threads 2001-2004' started by Chris M, Aug 30, 2002.
  1. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    From www.thedigitalbits.com
  2. Damin J Toell
    Damin J Toell Producer
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
  3. rutger_s
    rutger_s Supporting Actor
    Jul 7, 2000
    878
    Lilo and Stitch has an original intended AR of 1.66:1.
    The reason why its called "Family Friendly Widescreen" is because on 4:3, it fills most of the screen and on a widescreen TV, it pretty much fills the entire screen.
    The 1.66:1 frame is windowboxed inside a 1.78:1 window.
  4. Chris Dugger
    Chris Dugger Supporting Actor
    Jun 5, 1998
    665
    The film played in theatres at a ratio of 1.85:1.
    Dugger
  5. Tom M
    Tom M Stunt Coordinator
    Oct 6, 1999
    223
    6
    110
    I am a projectionist who is very familiar with Lilo And Stitch's AR. Earlier this summer and just this Thursday I had to splice together a print of this film.
    The image on the film is 1.85:1 hard matte. If the DVD is 1.66:1, then expect some minor panning and scanning. Of course, incorrect ARs have been listed before including on the actual packaging.
    I suggest not panicking untill we see what is on the actual disc. [​IMG]
  6. Jeffrey Gray
    Jeffrey Gray Second Unit
    Aug 11, 2001
    488
    The PRINTS were 1.85:1 hard-matte. The actual film is 1.66:1, since that's the AR of the films Disney has done with CAPS (save Atlantis).
  7. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,563
    195
    9,110
    Georgia (the state)
    Patrick McCart
    All of Disney's post Little Mermaid films, not in scope, were rendered at 1.66:1.
    The CAPS system is digital, so the entire image is done at 1.66:1. When it's put on film, it's hard-matted to 1.85:1 for theaters (to keep the composition from being off).
    A 1.66:1 version would have the entire existing image exposed, with no cropping outsie of STMPE framing.
  8. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    So, why not just show the feature at 1.66:1 in the theater!
    They do still display shows at that ratio! (don't they?)
    Makes no sense to me.
    Chris.
  9. Peter Apruzzese
    Peter Apruzzese Producer
    Dec 20, 1999
    3,516
    1,098
    4,110
    Peter Apruzzese
  10. AaronMK
    AaronMK Supporting Actor
    Oct 30, 1999
    768
    Orlando, FL
    Aaron Karp
  11. Patrick McCart
    May 16, 2001
    7,563
    195
    9,110
    Georgia (the state)
    Patrick McCart
  12. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
  13. AaronMK
    Oct 30, 1999
    768
    Orlando, FL
    Aaron Karp
    Anyone know what the "747" ending mentioned on The Digital Bits refers to?
  14. John Berggren
    John Berggren Producer
    Jun 17, 1999
    3,238
    1.66 is the proper AR for Lilo and Stitch, as with all modern Disney animated features which are not 2.35.
  15. Chris M
    Chris M Second Unit
    Apr 15, 2000
    487
    Well, as far as I knew OAR was for Original THEATRICAL Aspect Ratio... which is 1.85:1 BUT I can make an exception if the animators created the film in 1.66:1 and the film was matted in the theater for 1.85:1 for the reasons stated above.
    It makes no sense for Disney to do that... but whatever.
    Chris.
  16. Joshua Clinard
    Joshua Clinard Screenwriter
    Aug 25, 2000
    1,823
    69
    1,610
    Abilene, TX
    Joshua Clinard
    There can only be one correct aspect ratio. If the correct AR is 1.66:1, then the one matted for theaters is incorrect, and therfore, we should not view it in the theaters. If the one made for theaters is correct, then the DVD transfers are incorrect.
    Movies are made for the THEATER! Therefore, in my opinion, the 1.85:1 AR is the correct one, and we should DEMAND that we get the real thing. Not this "Family Freindly" Widescreen. I do not beleive we are missing anything in the theaters. Has anyone done any screen comparisons to PROVE that the DVD transfers are not missing any info on the sides??
  17. Jean-Michel
    Jean-Michel Supporting Actor
    Mar 28, 2002
    769
  18. Adam Lenhardt
    Adam Lenhardt Executive Producer
    Feb 16, 2001
    17,977
    2,359
    9,110
    Albany, NY
  19. Damin J Toell
    Mar 7, 2001
    3,762
    6
    Brooklyn, NY
    Damin J. Toell
    You should really do some research into the Disney animation process before you make such boldly incorrect assertions.
    DJ
  20. Patrick McCart
    May 16, 2001
    7,563
    195
    9,110
    Georgia (the state)
    Patrick McCart
