like the 3802
Discussion in 'Archived Threads 2001-2004' started by gene avallon, Jul 5, 2002.
  1. gene avallon
    gene avallon Stunt Coordinator
    Jun 13, 2001
    187
    I need something like the 3802 but with 7.1.was all set to buy 3802 till I checked the specs more closely,you all had me convinced. to make myself clearer,seven on board amps.
    gene[​IMG]
  2. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    I'm confused. The 3802 has 7 on-board amps!
  3. gene avallon
    Jun 13, 2001
    187
    it does? I gotta go look
    thanks
    gene
  4. gene avallon
    Jun 13, 2001
    187
    it does. dont be confused I am
    gene[​IMG]
  5. gene avallon
    Jun 13, 2001
    187
    now I have to see if I can get it for 699 at 6ave
    thank you thank you
    gene
  6. gene avallon
    Jun 13, 2001
    187
    I found out how I got mixed up when I went to 6ave I was looking at the 2802,a senior moment.
    gene:b
  7. gene avallon
    Jun 13, 2001
    187
    just ordered the 3802
    gene[​IMG]
  8. Gary Thomas
    Gary Thomas Second Unit
    Jan 17, 1999
    389
    Gene: I'm sure you will be very happy with the 3802. Actually, I have trouble justifying spending any more than $1000 for a receiver. The 3802 does just about everything you could want:
    It decodes everything, including DPLII, DTS & DD.
    It allows for 2 surround back center channels & I use the B surrounds for a pair of stereo speakers in my dining room.
    It's got plenty of power as I'm running 9 speakers off of this receiver! I can play my system as loud as you can stand. (I don't use my 3802 to power my sub)
    Realistically, I can't see spending a whole lot more for a receiver or separates. I think there would be diminishing returns. There are a lot of great receivers that offer similar quality: Yamaha, Marantz, Onkyo, Sony, etc. I think it comes down to how you value one or two particular features over another.
    I used to use a Denon 3300 as a pre w/ Marantz mono amps for my front channels. The 3802 on it's own sounds just as good.
    Now...those of you with high cost receivers or separates, don't get miffed. I'm talking in terms of a nice, normal HT set-up. Not for best of the best, state of the art, critical listening.
    Gene: Hook it up & enjoy!!!
    PS: I'll step down from my soapbox now!
  9. Chuck Kent
    May 29, 1999
    983
    Glad to help. Enjoy!!!
