Lighting question (Pronto related)....
Discussion in 'Archived Threads 2001-2004' started by Joe McCabe, Nov 13, 2001.
  1. Joe McCabe
    Joe McCabe Second Unit
    May 6, 1999
    336
    Ok, I need to know what remote system I should buy to enable me to have the lights go down, when I push "play" on my Pronto.
    I have read that this is possible with a certain remote dimmer systems.
    Does anyone have advice?
  2. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    Hi Joe,
    Yes, this is not only possible, it's not that difficult or expensive. I'm sure there are many ways to automate lighting and incorporate it into a macro on your Pronto. I chose to purchase a Lutron Spacer lighting package, installed the dimmer, then taught my Pronto the codes for the lights. The codes can then be incorporated into macros. In my case, I have a "Cinema" button on my Pronto that turns down the lights, starts some "Showtime" music, then switches the inputs and starts the DVD.
    I bought my Lutron package (remote control dimmer, accessory dimmer, remote control) online for around $75 (can't recall exact price).
    As I've said, I'm sure there are others ways to accomplish your goal. I know some of the members use X-10 hardware but I'm not too familiar with it so I can't comment on it.
    Hope this helps. If you have more questions, I'd be happy to help out.
    [​IMG]
