Hello,
Quick Q...
Does anyone know if it is possible to do the following.
Can I use Liberty RGB 5 cable to make the following.
With 3 wires out of the 5 RGB cables make the RED, GREEN & Blue Component Video Cables
With the last two of the 5 RGB cables make an s-video connection?
Can the RGB 5 coaxial be used to make an s-video connection using two of the wires in the RGB 5 cable?
Quick Q...
