Liberty cable?
Discussion in 'Archived Threads 2001-2004' started by JasonDG, Apr 16, 2002.
  1. JasonDG
    JasonDG Extra
    Apr 15, 2002
    16
    I just bought a set of Liberty Z300CV2 component video cables on ebay for $25.
    I was going to spend $30-40 on this cable at the store anyway, so that would have only bought el cheapos. I figure they're probably better than el cheapo, they actually look pretty good.
    Since I alerady bought it, I should probably not bring this up, but does anyone here have an opinion about Liberty cable? Has anyone heard of it?
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    I'm afraid I have never heard of this brand.
    Keep in mind that some companies dont actually make the coax. They buy the cable & connectors in bulk and wire/package the cables with their own name.
    A "better" choice in my opinion would be to have searched on eBay for "Canare". This will show you a bunch of auctions where people buy Canare/Belden parts and sell custom cables. (Canare & Belden are 2 brands that are very popular in the Broadcast & Production Studio industry. So you would be buying the same stuff used to master your CD/DVD's).
    May I ask:
    - How big is your display?
    - How long is your cable run?
    - Are you pushing Progressive or HD signal, or ordinary component video?
  3. JasonDG
    JasonDG Extra
    Apr 15, 2002
    16
    This is a legitimate company http://www.libertycable.com/
    The cable is THX certified. I'm not sure what that means in reality, but it should be good for something.
    I just acquired a 50" Mitsubishi HDTV ready. This is for a regular component video connection. The cables are 2 meters.
    I looked a bit for the canare stuff, but it all seems a bit out of my price range. I don't think I'm the type to really notice the difference between $50 cables and $200 cables, but I didn't want to go with the cheapo stuff.
  4. Bob McElfresh
    May 22, 1999
    5,182
  5. JasonDG
    JasonDG Extra
    Apr 15, 2002
    16
    I'm glad to hear some outside approval of these cables. I was trying to get some Monster Vid 3 component cables on ebay, but those auctions were going up to $65 or so. I just didn't want to pay that. So I took a chance on these.
    Since I have no other set for comparison I won't be able to give much useful feedback on their quality, but I'll try.
  6. Mike Breeden
    Mike Breeden Agent
    Nov 28, 2000
    39
    Jason
    I have all liberty cables in my system. I even have their 12gauge speaker cables. Onecall sells the cable pretty cheap as well. I love them. They made an improvement over my AR's that I had.
    Just my 2 cents
    Mike
