LG - RDJT 30 DLP projector
Discussion in 'Displays' started by Gurudristi, Mar 31, 2005.
  1. Gurudristi
    Gurudristi Auditioning
    Mar 30, 2005
    12
    hi guys, I am new to HT forum. Need help to find out more opinion on LG's RDJT 30 Projector. I just bought it. Though it display a wonderful picture. I was given to understand that it is not mountable on the ceiling.Though it has three screw holes at the bottom. Please advise where I can get any brackets for mounting.
  2. Gurudristi
    Mar 30, 2005
    12
    looks like I am one of the only few who has an LG projector! Though not so bad, it quite compact and portable. Any body else who has an LG.....
  3. Jeff Meyers
    Jeff Meyers Supporting Actor
    Feb 21, 2003
    605
    I don't have an LG projector (or any projector for that matter - I'm still trying to make a decision and save for one). Anyway, I have come across a couple different "universal" projector mounts that should (might) work in your instance.
    Here's one for $90:
    http://www.cdw.com/shop/products/def...spx?edc=723695
    You should be able to find some other universal mount options with a little searching. Check-out the vendors in the HTF Mall - I'm guessing that one of them should be able to assist you:
    http://www.hometheaterforum.com/mall/index.php
    Also, you should check-out ProjectorCental. They have the specs and some reviews for your projector here:
    http://www.projectorcentral.com/LG_E...cs-RD-JT30.htm
    And they have a listing of Ceiling Mount Suppliers here:
    http://www.projectorcentral.com/proj...ing-mounts.htm
    Good Luck!
