MichaelM
- Oct 14, 2002
Hello:
I just got a Widescreen Sony 30" HDTV with an HDMI input and an LG DVD Player (LGDVB418) that upconverts to 720/1080. I have it hooked up to the TV via the HDMI cable. My questions are:
1. Will I still get progressive scan with the HDMI input? In the manual for the DVD player it talks about progressive scan in relation to the component inputs but doesn't mention it for HDMI. Also, on the back of the DVD Player, it is labeled "Component Output/Progressive Scan" and for the HDMI it just says "HDMI". Which will produce a better picture? I'm worried that by using the HDMI I will not get progressive scan and may not be gettting the best picture in the end.
2. If I do use the component outputs of the DVD Player will I still get the upconversion or does that just work when you are using an HDMI cable?
Thanks a lot!
Mike
Thanks a lot!
Mike
