Robert_Zohn
Value Electronics
Insider
Scarsdale, NY
Robert Zohn
AMD’s website lists all LG TVs as FreeSync Premium and the 77GX is the only TV listed as FreeSync Premium Pro, https://www.amd.com/en/products/freesync-tvs .
The other thing to note is that Gsync has a lot of meaning for PC gamers. NVIDIA’s market share in PC gaming GPU is around 90%; so Gsync is essential to most serious PC gamers.
Consoles, e.g. Xbox support both FreeSync and the open standard HDMI VRR. LG VRR capable TVs have supported HDMI VRR since launch, so have always been compatible with consoles. Adding FreeSync therefore is only really relevant to the < 10% of PC gamers with AMD GPUs, which is why we see most of LG gaming promotion on NVIDIA and Gsync.
TheFOMO
California, USA
QT Fomo
77GX and 86NANO91 (strange choice)!
Any information you can get from LG about what makes these 2 TVs "Pro" is much appreciated, thanks Robert!
  • Like
Reactions: Robert_Zohn
Sam Posten
Aberdeen, MD & Navesink, NJ
Sam Posten
What are your thoughts on selling the 2080Ti (for almost cost) to buy the coming 3080Ti?
I know I know, stop the FOMO!
We will see. It would have to have a greater than 50% improvement in RTX for me to consider it. This was the most expensive computer component I have ever made. I hoped to get 3-4 years out of it. I bought it at launch so I've gotten as much value out of it as anyone.
Sam Posten
Sam Posten
After using the 48" CX I've made the decision to not use it as a computer monitor any more. Will be taking it down off the wall and swapping it for where my 55c7 is used for Xbox and Playstation gaming. This is not wholly unexpected, I was worried the CX would be too big as a general purpose monitor and it really is. In the way I expected and also in a way I was not.
First, the eye and neck movement to try to see activity in all corners is exhausting. I expected that but its worse than I feared. What I didn't expect was how frustrated I would be with Windows scaling. Both text and graphics just look wrong in everything I do, from web browsing to doc edits to just looking at the home screen. It seems that for ME personally 27" at native 1440P seems to be the right maximum screen size combo.
The good news is I can now sell off the 55 and put those funds towards and X1X and will be ready on day 1 to use that for 120hz and VRR. =)
Other than that the CX is awesome so far. Only complaint: It seems they missed including the bolts to attach the stand. I gotta run to Home Depot today to go get those...
TheFOMO
California, USA
QT Fomo
Thanks for that assessment Sam! I too was afraid of this - PC monitors are designed to be used/viewed with specific fields of view and resolutions optimized for desktop duty (18" to 24" away), but with a 48" size, suddenly, this distance must be adjusted which throws everything off - distance, resolution and lighting do not scale linearly! This is why I'm utterly aghast at the super curved 49" super wide G9 monitor recently released by Samsung, a trend I expect will end quickly.
Sam Posten
Sam Posten
That's awesome to hear. I am happy you are happy with it. Mine has taken to console gaming like a champ. Watching a lot of DV content over Xbox too. Just need to upgrade the receiver to be ready for next gen VRR / 120hz.
mkoenig4
Marc Koenig, Sr
Sound drop out on HDMI input 1 only. LG OLED CX 77”
Not sure if I should post in this discussion thread or make it a new discussion in the forum. Please advise me if I should post it elsewhere.
I have owned a LG OLED CX 77” for about two weeks (already owned a 65” B6 and 65” C7). Suddenly today while watching the TV the audio started dropping out. A consistent, non stop in and out. Sound on for about a second then off for a sec and then on, etc. I believe I have isolated it to a problem with the HDMI 1 input. However, I will explain my trouble shooting so far if you want to see how I reached that conclusion. Otherwise, feel free to jump to the next paragraph.
My setup consists of the LG TV, a 4K AppleTV on input HDMI 1, Oppo 4K/Blu-ray player on input HDMI 3 and sound to a Sonos Arc via HDMI 2/eArc. I initially suspect the Sonos connection but ruled that out after multiple Sonos trouble shooting steps. Also, the problem continued when I disconnected the Sonos and switched to the TV internal speakers. I made sure all HDMI cables were fully inserted. I restarted the AppleTV a few times. Never helped. Then I switched to watching a DVD (HDMI 3) and the sound was fine, with the Sonos hooked up. I used Apps in the TV (Hulu and Netflix) and the sound was fine. If I went back to any app playing from AppleTV (HDMI 1) it was always dropping out still. So, I thought the problem may be the AppleTV. However, when I connected the AppleTV to the cable going to the HDMI 3 input the sound was fine. And, when I connected the DVD player to the cable going to the HDMI 1 input the sound was again constantly dropping out. So, that showed it wasn’t an AppleTV issue. It had to be an issue with the HDMI 1port itself or the cord connected to the HDMI 1 port. I have the same brand/model cables going to all ports, brand new AudioQuest Pearl 5m cables. So, finally I swapped the actually cables going into the HDMI 1 port and the other 2 ports. Turns out that the AppleTV and DVD have no sound issues when using any of the 3 different cables when hooked to HDMI 3 or 4. However, the sound problem persists no matter which of the 3 cables I connect or source device I connect to HDMI 1.
So, the problem is with HDMI 1 port, correct? I have been using HDMI 1 for my main viewing since I set up the new TV. It just suddenly started having the sound drop out today. It was even working OK earlier today.
Any suggestion or ideas? Thanks.
Sam Posten
Sam Posten
Do you have full 48Gbit HDMI cables? If not, that's it. If you do It's almost definitely the Sonos. Make sure you have the latest firmware on your TV and all peripherals. I don't run a Sonos so can't help you there but it's very suspect.
mkoenig4
Marc Koenig, Sr
Yes, I have 48Gbit cables. Also, my trouble-shooting steps show it is unrelated to any peripheral, including the Sonos arc. The problem persisted with the Sonos disconnected and when listening through the TVs internal speakers. However, at someone‘s suggestion, I unplugged the TV from the wall/power and then plugged it back in. HDMI input 1 has been free of the problem since, for the last 24hrs. I’ll wait and see if the problem comes back.
Thanks.
  • Like
Reactions: Sam Posten
PhishHead00
