LFE Setting
Discussion in 'Archived Threads 2001-2004' started by Todd_Petersen, Oct 14, 2002.
  1. Todd_Petersen
    Todd_Petersen Stunt Coordinator
    Oct 4, 2002
    161
    I was just wondering on my onkyo 797 I have 2 Sub levles i can adjust. One is the one that emits the pink noise which i have like at -7db. Then there is a Dolby LFE asjustment that can go 0db down to -12 i think. What is the difference and how should i set them up for best performance?
  2. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    the sub adjustment adjusts your overall sub level, (including redirected bass from all channels set to 'small') while the LFE adjustment adjusts ONLY the .1 LFE channel when listening to a DD or DTS track. You'll most likely want to leave your LFE setting at 0db's, and calibrate your system using test tones and the sub adjustment setting.
