Christopher_Ham
- Sep 18, 2003
My Lexicon preamp has LFE mix level adjustments seperatley of the Sub level adjustments. The owners manual just says that when you send the bass from all speakers in addition to the LFE channel sometimes it is too much bass, use the LFE mix level to adjust, but no advice. How do I properly set it. All speakers are set to 80hz cutoff and I am using a PB2+ sub.
Thanks for advice
Chris
Thanks for advice
Chris
