lfe level (1 Viewer)
Ronneil Camara
Hi guys,
I have a yamaha receiver. I am in the manual setup. I saw 2 options under LFE Level and that is HP LFE and SP LFE. Setting is both currently at 0. I cannot increment it but I can decrement the value to negative. What is this for and what is the appropriate value?
Thanks guys,
Neil
Ilkka R
Ilkka
SP means speakers and HP headphones. You should set both at 0. This means you won't lower the LFE level, which you don't want to do. If you lower it, the LFE signal gets lower, simple as that.
And yes, rtfm, this all is explained there also...
TheThrillisgone
