Matt Tucker
When I moved recently, I set up the AV system with a electronic crossover I made. I prefer the sound of my crossover (especially for music) to the built in crossover of my Marantz AV-550. The Marantz has the x-over frequency set higher (100HZ) and possibly uses a less steep slope. My homebuilt x-over is 24db/octave at 85HZ.
Music sounds great, but I keep thinking that the movies are not hitting me with bass as hard as they use to. I was using the LFE channel with all speakers set for "small" before I moved.
I now have all non-main speakers set to small and have the main speakers set to large. The Maraantz manual says that it routes all bass from the small speakers to the main speakers (if set to large)if the subwoofer option is turned off.
I was thinking that maybe I am missing some bass because I am not using the LFE channel. Perhaps this is all in my head because a Dolby information page http://www.dolby.com/tech/L.mn.0002.5.1Guide.s.pdf says "If no subwoofer is present, the bass (including the LFE channel, if it exists) is redirected to the speakers best able to produce it, usuall the main stereo pair" I used 20-60HZ sine waves to listen for any dips in response for the current subwoofer location and like I said, music bass sounds great.
Is it in my head, or is it possible the LFE channel is not getting routed to the main speakers?
Matt
Matt
